Giriş
This guide will instruct you on how to replace the motherboard of the Samsung Mythic SGH-a897. To successfully remove the motherboard tweezers will be used to remove cables, ribbons flip levers, and remove components.
Neye ihtiyacın var
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
