Ana içeriğe geç
Samsung Mythic SGH-a897 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Mythic SGH-a897 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Motherboard Replacement: adım 2, 1 resimden 1.
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Motherboard Replacement, Rear Case: adım 3, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Motherboard Replacement: adım 4, 1 resimden 1.
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Motherboard Replacement, Camera: adım 5, 2 resimden 1. Samsung Mythic SGH-a897 Motherboard Replacement, Camera: adım 5, 2 resimden 2.
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 Motherboard Replacement: adım 7, 2 resimden 1. Samsung Mythic SGH-a897 Motherboard Replacement: adım 7, 2 resimden 2.
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 Motherboard Replacement: adım 9, 2 resimden 1. Samsung Mythic SGH-a897 Motherboard Replacement: adım 9, 2 resimden 2.
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 Motherboard Replacement: adım 10, 2 resimden 1. Samsung Mythic SGH-a897 Motherboard Replacement: adım 10, 2 resimden 2.
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 Motherboard Replacement: adım 11, 1 resimden 1.
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 Motherboard Replacement: adım 12, 2 resimden 1. Samsung Mythic SGH-a897 Motherboard Replacement: adım 12, 2 resimden 2.
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 Motherboard Replacement: adım 13, 2 resimden 1. Samsung Mythic SGH-a897 Motherboard Replacement: adım 13, 2 resimden 2.
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
Sonuç
Morgan Yost
46 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-1, Regan Spring 2013 Cal Poly, Team 17-1, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G1
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 462
