Ana içeriğe geç
Samsung Mythic SGH-a897 Speaker Replacement
Neye ihtiyacın var
  1. Samsung Mythic SGH-a897 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Speaker Replacement: adım 2, 1 resimden 1.
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Speaker Replacement, Rear Case: adım 3, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Speaker Replacement: adım 4, 1 resimden 1.
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Speaker Replacement, Speaker: adım 5, 2 resimden 1. Samsung Mythic SGH-a897 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Sonuç
Morgan Yost
46 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-1, Regan Spring 2013 Cal Poly, Team 17-1, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G1
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 253
