Ana içeriğe geç
Samsung N150 Plus RAM Replacement
Neye ihtiyacın var
  1. Samsung N150 Plus RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung N150 Plus RAM Replacement: adım 2, 2 resimden 1. Samsung N150 Plus RAM Replacement: adım 2, 2 resimden 2.
    • Slide the left and right switch to the "unlocked" position.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung N150 Plus RAM Replacement: adım 3, 2 resimden 1. Samsung N150 Plus RAM Replacement: adım 3, 2 resimden 2.
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung N150 Plus RAM Replacement, Back Panel: adım 4, 1 resimden 1.
    • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung N150 Plus RAM Replacement: adım 5, 1 resimden 1.
    • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Apply pressure upwards till the back panel pops off.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung N150 Plus RAM Replacement: adım 6, 2 resimden 1. Samsung N150 Plus RAM Replacement: adım 6, 2 resimden 2.
    • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung N150 Plus RAM Replacement, RAM: adım 7, 2 resimden 1. Samsung N150 Plus RAM Replacement, RAM: adım 7, 2 resimden 2.
    • Using your hands, push the two metal clip holders on each side away from the RAM till you hear a clicking sound.
    • If you push the metal rods away from the RAM as directed, the RAM will pop up at an angle.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung N150 Plus RAM Replacement: adım 8, 1 resimden 1.
    • Gently pull out the stick of RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
There is no need to open the entire casing. There is a special lid on the back that covers the SODIMM for easy access. It can be replaced removing only one screw.
Fred - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 2,282
