Ana içeriğe geç
Samsung NP N310 HAA2US Back Panel Replacement
Neye ihtiyacın var
  1. Samsung NP N310 HAA2US Back Panel Replacement, Battery: adım 1, 3 resimden 1. Samsung NP N310 HAA2US Back Panel Replacement, Battery: adım 1, 3 resimden 2. Samsung NP N310 HAA2US Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: adım 2, 2 resimden 1. Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: adım 2, 2 resimden 2.
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Back Panel Replacement: adım 3, 3 resimden 1. Samsung NP N310 HAA2US Back Panel Replacement: adım 3, 3 resimden 2. Samsung NP N310 HAA2US Back Panel Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
Sonuç
Amir Afridi
626 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Passmore Fall 2016 USF Tampa, Team 4-1, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 308
