Giriş
If the laptop is making noises, it may have something caught in the fan. These are often tiny particles that are hard to reach. It can be fix by taking the fan out and cleaning it with compressed air or replacing it with a new fan.
Neye ihtiyacın var
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
Remove the 3 Phillips 4.5mm silver screws on the fan. Use a size 1 Phillips screwdriver
Remove the 1 Phillips 8mm black screw on the fan. Use a size 1 Phillips screwdriver.
