Ana içeriğe geç
Samsung NP N310 HAA2US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP N310 HAA2US RAM Replacement, Battery: adım 1, 3 resimden 1. Samsung NP N310 HAA2US RAM Replacement, Battery: adım 1, 3 resimden 2. Samsung NP N310 HAA2US RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US RAM Replacement, RAM: adım 2, 3 resimden 1. Samsung NP N310 HAA2US RAM Replacement, RAM: adım 2, 3 resimden 2. Samsung NP N310 HAA2US RAM Replacement, RAM: adım 2, 3 resimden 3.
    • Locate and unscrew the 5mm screw on the small panel on the back that has 'memory' written on it.
    • Pull off the memory panel.
  3. Samsung NP N310 HAA2US RAM Replacement: adım 3, 3 resimden 1. Samsung NP N310 HAA2US RAM Replacement: adım 3, 3 resimden 2. Samsung NP N310 HAA2US RAM Replacement: adım 3, 3 resimden 3.
    • Pull the 2 latches holding the RAM in, away from the RAM stick, and the RAM will pop up.
    • Pull the RAM out of the slot, only touching the edges of the RAM stick
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amir Afridi
626 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Passmore Fall 2016 USF Tampa, Team 4-1, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G1
4 Üyeler
Bir Yorum
I checked out this guide today (11.2022) to upgrade the RAM in my N310 Windows XP laptop that I bought in the summer of 2009 : ) a whooping 2 GB of DDR2 RAM installed to play old games on original hardware... yee haw!
Mick Germ - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 291
