Giriş
An overheating laptop is a common problem when the internal fan of the computer is either blocked or not working properly.
Excessive heat in your computer will cause it to turn off, and might lead to performance problems in the future. Cleaning or replacing the fan is a cheap way of solving the problem.
Neye ihtiyacın var
Turn off the computer.
Disconnect the charger cable from the computer.
Flip the computer over so the underside is facing up.
Using a Phillips 1 screwdriver, carefully remove all 12 screws of the back cover.
With the plastic opening tool, carefully separate the back cover from the computer frame.
Starting at one of the corners of the computer, work your way around the edge until you reach the other corner.
As you go around the sides of the computer, free the inside latches with the plastic opening tool.
Once you have an opening, carefully use your hands to separate the back cover.
Bir başkası bu kılavuzu tamamladı.
