Ana içeriğe geç
Samsung NP-130-JA01US Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP-130-JA01US Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Hard Drive Replacement: adım 2, 2 resimden 1. Samsung NP-130-JA01US Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Samsung NP-130-JA01US Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Using a Philips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Hard Drive Replacement: adım 5, 3 resimden 1. Samsung NP-130-JA01US Hard Drive Replacement: adım 5, 3 resimden 2. Samsung NP-130-JA01US Hard Drive Replacement: adım 5, 3 resimden 3.
    • With the plastic opening tool, carefully separate the back cover from the computer frame.
    • Starting at one of the corners of the computer, work your way around the edge until you reach the other corner.
    • Do not attempt to pry it open, putting too much force into one location might damage the computer.
    • As you go around the sides of the computer, free the inside latches with the plastic opening tool.
    • Once you have an opening, carefully use your hands to separate the back cover.
  6. Samsung NP-130-JA01US Hard Drive Replacement: adım 6, 2 resimden 1. Samsung NP-130-JA01US Hard Drive Replacement: adım 6, 2 resimden 2.
    • Locate Hard Drive (red square)
    • Using a Phillips 1 screw driver, remove the screw marked in the red circle.
    • The screw is a Phillips 1 (PH 1) with a length of 40 millimeters (mm)
    • Unscrew carefully to prevent losing or breaking pieces.
  7. Samsung NP-130-JA01US Hard Drive Replacement: adım 7, 2 resimden 1. Samsung NP-130-JA01US Hard Drive Replacement: adım 7, 2 resimden 2.
    • Gently remove the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jorge Quintana
260 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 694
