Ana içeriğe geç
Samsung NP-130-JA01US Keyboard Replacement
Neye ihtiyacın var
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung NP-130-JA01US Keyboard Replacement: adım 2, 2 resimden 1. Samsung NP-130-JA01US Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the left and right slider buttons fully away from each other.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung NP-130-JA01US Keyboard Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung NP-130-JA01US Keyboard Replacement: adım 5, 3 resimden 1. Samsung NP-130-JA01US Keyboard Replacement: adım 5, 3 resimden 2. Samsung NP-130-JA01US Keyboard Replacement: adım 5, 3 resimden 3.
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
    FixBot'a Sor
    Yorum Ekle
  6. Samsung NP-130-JA01US Keyboard Replacement: adım 6, 3 resimden 1. Samsung NP-130-JA01US Keyboard Replacement: adım 6, 3 resimden 2. Samsung NP-130-JA01US Keyboard Replacement: adım 6, 3 resimden 3.
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alejandro Guerra Piol
319 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G6
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 39
Her zaman: 664
