Ana içeriğe geç
Samsung NP-130-JA01US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP-130-JA01US RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung NP-130-JA01US RAM Replacement: adım 2, 2 resimden 1. Samsung NP-130-JA01US RAM Replacement: adım 2, 2 resimden 2.
    • Slide the left and right slider buttons fully away from each other.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung NP-130-JA01US RAM Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung NP-130-JA01US RAM Replacement, RAM: adım 4, 2 resimden 1. Samsung NP-130-JA01US RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Locate the "Memory" panel on the bottom right corner.
    • Use the Phillips 01 screwdriver to remove the screw.
    • The screw is a Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    FixBot'a Sor
    Yorum Ekle
  5. Samsung NP-130-JA01US RAM Replacement: adım 5, 1 resimden 1.
    • With your hand, lift panel and remove it.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung NP-130-JA01US RAM Replacement: adım 6, 2 resimden 1. Samsung NP-130-JA01US RAM Replacement: adım 6, 2 resimden 2.
    • Slide metal prongs (marked in red squares) away from each other with your fingers.
    • The RAM chip will automatically lift up at an angle for easy ejection.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung NP-130-JA01US RAM Replacement: adım 7, 1 resimden 1.
    • With your hands, carefully slide the RAM chip out to remove.
    • The RAM chip is delicate, do not force it when removing it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jason Schnebelen
267 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G6
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 521
