Ana içeriğe geç
Samsung NP-N102S-B05PH Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Before replacing a hard drive, have a backup of original files if files are needed to be recovered afterward.
    • Power down your laptop, and position the laptop with the bottom cover facing upwards.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the nine 6.5 mm screws.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use an opening to pry off the bottom cover, clips.
    • Potential for device damage. Before proceeding, be sure to be grounded, as existing static can be transferred and cause significant damage to the device. Wear an anti-static wristband for additional protection.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 4, 3 resimden 1. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 4, 3 resimden 2. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 5, 3 resimden 1. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 5, 3 resimden 2. Samsung NP-N102S-B05PH Hard Drive Replacement: adım 5, 3 resimden 3.
    • Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
    • The hard drive is now fully removed from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Rudzik
349 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Nance Fall 2016 USF Tampa, Team 2-4, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,563
