Ana içeriğe geç
Samsung NP-N102S-B05PH Speaker Replacement
Neye ihtiyacın var
  1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: adım 1, 3 resimden 1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: adım 1, 3 resimden 2. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Place the laptop face-down on a stable surface.
    • Remove the nine 6.5mm Phillips #0 screws shown.
    • Use the blue opening tool to gently pry the back of the laptop off of the body.
  2. Samsung NP-N102S-B05PH Speaker Replacement: adım 2, 3 resimden 1. Samsung NP-N102S-B05PH Speaker Replacement: adım 2, 3 resimden 2. Samsung NP-N102S-B05PH Speaker Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the six 4.5mm screws holding the motherboard to the case.
  3. Samsung NP-N102S-B05PH Speaker Replacement: adım 3, 2 resimden 1. Samsung NP-N102S-B05PH Speaker Replacement: adım 3, 2 resimden 2.
    • Use the spudger to remove the red and black cable located above the speaker from it's connector.
    • Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
    • Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
  4. Samsung NP-N102S-B05PH Speaker Replacement: adım 4, 1 resimden 1.
    • Gently unhook the red and black wires from the plastic clips holding them to the case. This can be done with only your fingers.
  5. Samsung NP-N102S-B05PH Speaker Replacement: adım 5, 1 resimden 1.
    • Using the spudger, lift the speaker up and out of it's holder, as shown. The yellow plastic tape should peel off as well.
Sonuç
Lennon Grimm
247 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Nance Fall 2016 USF Tampa, Team 2-4, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,140
