Giriş
This guide will provide instructions on how to fully replace the battery on a Samsung N145 laptop. You will be given steps on how to detach the current battery of your device and attach a new one. You will want to perform this replacement if the battery of your device does not charge when it's plugged in or it does not hold a charge.
Locate both the battery locking latches on the lower right and left sides of the battery.
Slide both locking latches outwards simultaneously to unlock the battery.
While holding the locking latches in the outward position, pull the battery off and set it off to the side.
Release the locking latches after completely removing the battery.
Bir başkası bu kılavuzu tamamladı.
