Ana içeriğe geç
Samsung NP-N145-JP02US Fan Replacement
Neye ihtiyacın var
  1. Samsung NP-N145-JP02US Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Before starting the replacement, turn off the device sure and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Fan Replacement: adım 2, 1 resimden 1.
    • Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
    • Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
  3. Samsung NP-N145-JP02US Fan Replacement: adım 3, 1 resimden 1.
    • Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
  4. Samsung NP-N145-JP02US Fan Replacement: adım 4, 1 resimden 1.
    • Manually remove the fan from the device by pulling out the connector.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 591
