Ana içeriğe geç
Samsung NP-N145-JP02US Screen Replacement
Neye ihtiyacın var
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: adım 3, 1 resimden 1.
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: adım 4, 3 resimden 1. Samsung NP-N145-JP02US Screen Replacement: adım 4, 3 resimden 2. Samsung NP-N145-JP02US Screen Replacement: adım 4, 3 resimden 3.
    • Using your fingertips, gently pull screen to pop it out of the frame.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 419
