Ana içeriğe geç
Samsung NP-N210-JA02US Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP-N210-JA02US Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Samsung NP-N210-JA02US Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Carefully slide both locking pins to the unlocked position.
  2. Samsung NP-N210-JA02US Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery out of its housing.
  3. Samsung NP-N210-JA02US Hard Drive Replacement, Hard Drive Removal: adım 3, 1 resimden 1.
    • Remove the following 14 screws:
    • Thirteen 5 mm Phillips #1 screws
    • One 3.5 mm Philips #001 screw
  4. Samsung NP-N210-JA02US Hard Drive Replacement: adım 4, 1 resimden 1.
    • Carefully insert the plastic opening tool into the seam between the lower casing and the chrome bezel.
  5. Samsung NP-N210-JA02US Hard Drive Replacement: adım 5, 1 resimden 1.
    • Slide the opening tool across all sides of the lower case. Then, lift it up to remove the case and reveal the internal components.
  6. Samsung NP-N210-JA02US Hard Drive Replacement: adım 6, 3 resimden 1. Samsung NP-N210-JA02US Hard Drive Replacement: adım 6, 3 resimden 2. Samsung NP-N210-JA02US Hard Drive Replacement: adım 6, 3 resimden 3.
    • Carefully unplug the SATA connector from the hard drive.
  7. Samsung NP-N210-JA02US Hard Drive Replacement: adım 7, 2 resimden 1. Samsung NP-N210-JA02US Hard Drive Replacement: adım 7, 2 resimden 2.
    • Remove the four black 3.5 mm Philips #1 screws on the (side) of the hard drive.
  8. Samsung NP-N210-JA02US Hard Drive Replacement: adım 8, 1 resimden 1.
    • Gently lift the hard drive from its mounting bracket.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Afif Chehabaldeen
401 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 3,924
