Ana içeriğe geç
Samsung NP-NC10-KA02US Fan Replacement
Neye ihtiyacın var
  1. Samsung NP-NC10-KA02US Fan Replacement, Battery: adım 1, 2 resimden 1. Samsung NP-NC10-KA02US Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Fan Replacement: adım 2, 1 resimden 1.
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Fan Replacement: adım 3, 1 resimden 1.
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Fan Replacement, Back Plate: adım 4, 1 resimden 1.
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Fan Replacement: adım 5, 1 resimden 1.
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Fan Replacement: adım 6, 2 resimden 1. Samsung NP-NC10-KA02US Fan Replacement: adım 6, 2 resimden 2.
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US Fan Replacement, Fan: adım 7, 2 resimden 1. Samsung NP-NC10-KA02US Fan Replacement, Fan: adım 7, 2 resimden 2.
    • Remove the three screws holding the fan using a 3.9mm screwdriver.
    • All three screws need to be removed in order to continue on to next step.
  8. Samsung NP-NC10-KA02US Fan Replacement: adım 8, 1 resimden 1.
    • Unplug the wires connected to the fan using a plastic opening tool.
  9. Samsung NP-NC10-KA02US Fan Replacement: adım 9, 1 resimden 1.
    • You are now able to carefully detach the fan from the base.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
JHOAN USECHE
372 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Sullivan Fall 2016 USF Tampa, Team 1-1, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S1G1
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 50
Her zaman: 1,020
