Giriş
If your computer is not turning on or is losing power quickly, this guide provides steps to replace the battery. The optical drive, hard drive, and back cover must be removed first.
Neye ihtiyacın var
Flip the laptop over.
Remove the 6 mm screw with the Phillips #000 screwdriver.
Flip the laptop.
Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Pardon the interruption, but do you potentially have a tutorial on how to replace the keyboard on this laptop? I am having problems finding an acceptable-enough tutorial on how to do it, yet I need such a tutorial as the process seems quite daunting.
Thanks,
Random Person on the Internet
