Ana içeriğe geç
Samsung NP-QX411L Hinges Replacement
Neye ihtiyacın var
    1. Samsung NP-QX411L Hinges Replacement, Optical Drive: adım 1, 2 resimden 1. Samsung NP-QX411L Hinges Replacement, Optical Drive: adım 1, 2 resimden 2.
      • Flip the laptop over.
      • Remove the 6 mm screw with the Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung NP-QX411L Hinges Replacement: adım 2, 1 resimden 1.
      • Slide out the optical drive to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung NP-QX411L Hinges Replacement, Hard Drive: adım 3, 2 resimden 1. Samsung NP-QX411L Hinges Replacement, Hard Drive: adım 3, 2 resimden 2.
      • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
      • Flip the laptop.
      • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung NP-QX411L Hinges Replacement: adım 4, 2 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 4, 2 resimden 2.
      • Gently wedge the spudger under the square panel.
      • Run the spudger under the edges of the square panel to loosen it.
      • Remove the panel.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung NP-QX411L Hinges Replacement: adım 5, 1 resimden 1.
      • Remove the hard drive slowly because it is still connected to a wire.
      • Pull up on the rubber flap or use the spudger to lift the hard drive.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung NP-QX411L Hinges Replacement: adım 6, 1 resimden 1.
      • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung NP-QX411L Hinges Replacement, Hinges: adım 7, 2 resimden 1. Samsung NP-QX411L Hinges Replacement, Hinges: adım 7, 2 resimden 2.
      • Disconnect the wire from the motherboard by pulling up and away from the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung NP-QX411L Hinges Replacement: adım 8, 2 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 8, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the top two rubber stoppers using precision tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung NP-QX411L Hinges Replacement: adım 9, 1 resimden 1.
      • Unscrew nine 6 mm screws on the cover using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung NP-QX411L Hinges Replacement: adım 10, 3 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 10, 3 resimden 2. Samsung NP-QX411L Hinges Replacement: adım 10, 3 resimden 3.
      • Wedge the spudger under the cover to gently pry it up.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung NP-QX411L Hinges Replacement: adım 11, 3 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 11, 3 resimden 2. Samsung NP-QX411L Hinges Replacement: adım 11, 3 resimden 3.
      • Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung NP-QX411L Hinges Replacement: adım 12, 3 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 12, 3 resimden 2. Samsung NP-QX411L Hinges Replacement: adım 12, 3 resimden 3.
      • Use precision tweezers to pop the antenna wires off of the WiFi card.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung NP-QX411L Hinges Replacement: adım 13, 3 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 13, 3 resimden 2. Samsung NP-QX411L Hinges Replacement: adım 13, 3 resimden 3.
      • Open the laptop slightly.
      • Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung NP-QX411L Hinges Replacement: adım 14, 1 resimden 1.
      • Hold hinges in place with your thumb and slide the laptop away from the screen.
      FixBot'a Sor
      Yorum Ekle
    9. Samsung NP-QX411L Hinges Replacement: adım 15, 2 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 15, 2 resimden 2.
      • Remove the 4 rubber stoppers with the precision tweezers.
      FixBot'a Sor
      Yorum Ekle
    10. Samsung NP-QX411L Hinges Replacement: adım 16, 2 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 16, 2 resimden 2.
      • Remove the four 4 mm screws with a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    11. Samsung NP-QX411L Hinges Replacement: adım 17, 2 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 17, 2 resimden 2.
      • The metal spudger could scratch the screen.
      • Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
      FixBot'a Sor
      Yorum Ekle
    12. Samsung NP-QX411L Hinges Replacement: adım 18, 2 resimden 1. Samsung NP-QX411L Hinges Replacement: adım 18, 2 resimden 2.
      • Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Rebecca Johnson
594 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G3, Hoffman Spring 2017 USF Tampa, Team S19-G3, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G3
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,109
