Ana içeriğe geç
Samsung NP-QX411L Screen Replacement
Neye ihtiyacın var
  1. Samsung NP-QX411L Screen Replacement, Optical Drive: adım 1, 2 resimden 1. Samsung NP-QX411L Screen Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Remove the 6 mm screw with the Phillips #000 screwdriver.
  2. Samsung NP-QX411L Screen Replacement: adım 2, 1 resimden 1.
    • Slide out the optical drive to remove it.
  3. Samsung NP-QX411L Screen Replacement, Hard Drive: adım 3, 2 resimden 1. Samsung NP-QX411L Screen Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
  4. Samsung NP-QX411L Screen Replacement: adım 4, 2 resimden 1. Samsung NP-QX411L Screen Replacement: adım 4, 2 resimden 2.
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
  5. Samsung NP-QX411L Screen Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
  6. Samsung NP-QX411L Screen Replacement: adım 6, 1 resimden 1.
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
  7. Samsung NP-QX411L Screen Replacement, Hinges: adım 7, 2 resimden 1. Samsung NP-QX411L Screen Replacement, Hinges: adım 7, 2 resimden 2.
    • Disconnect the wire from the motherboard by pulling up and away from the laptop.
  8. Samsung NP-QX411L Screen Replacement: adım 8, 2 resimden 1. Samsung NP-QX411L Screen Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the top two rubber stoppers using precision tweezers.
  9. Samsung NP-QX411L Screen Replacement: adım 9, 1 resimden 1.
    • Unscrew nine 6 mm screws on the cover using a Phillips #000 screwdriver.
  10. Samsung NP-QX411L Screen Replacement: adım 10, 3 resimden 1. Samsung NP-QX411L Screen Replacement: adım 10, 3 resimden 2. Samsung NP-QX411L Screen Replacement: adım 10, 3 resimden 3.
    • Wedge the spudger under the cover to gently pry it up.
  11. Samsung NP-QX411L Screen Replacement: adım 11, 3 resimden 1. Samsung NP-QX411L Screen Replacement: adım 11, 3 resimden 2. Samsung NP-QX411L Screen Replacement: adım 11, 3 resimden 3.
    • Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
  12. Samsung NP-QX411L Screen Replacement: adım 12, 3 resimden 1. Samsung NP-QX411L Screen Replacement: adım 12, 3 resimden 2. Samsung NP-QX411L Screen Replacement: adım 12, 3 resimden 3.
    • Use precision tweezers to pop the antenna wires off of the WiFi card.
  13. Samsung NP-QX411L Screen Replacement: adım 13, 3 resimden 1. Samsung NP-QX411L Screen Replacement: adım 13, 3 resimden 2. Samsung NP-QX411L Screen Replacement: adım 13, 3 resimden 3.
    • Open the laptop slightly.
    • Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
  14. Samsung NP-QX411L Screen Replacement: adım 14, 1 resimden 1.
    • Hold hinges in place with your thumb and slide the laptop away from the screen.
  15. Samsung NP-QX411L Screen Replacement: adım 15, 2 resimden 1. Samsung NP-QX411L Screen Replacement: adım 15, 2 resimden 2.
    • Remove the 4 rubber stoppers with the precision tweezers.
  16. Samsung NP-QX411L Screen Replacement: adım 16, 2 resimden 1. Samsung NP-QX411L Screen Replacement: adım 16, 2 resimden 2.
    • Remove the four 4 mm screws with a Phillips #000 screwdriver.
  17. Samsung NP-QX411L Screen Replacement: adım 17, 2 resimden 1. Samsung NP-QX411L Screen Replacement: adım 17, 2 resimden 2.
    • The metal spudger could scratch the screen.
    • Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
  18. Samsung NP-QX411L Screen Replacement: adım 18, 2 resimden 1. Samsung NP-QX411L Screen Replacement: adım 18, 2 resimden 2.
    • Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
  19. Samsung NP-QX411L Screen Replacement, Screen: adım 19, 2 resimden 1. Samsung NP-QX411L Screen Replacement, Screen: adım 19, 2 resimden 2.
    • Remove the four 4 mm screws using Phillips #000 screwdriver.
    • Remove metal brackets.
  20. Samsung NP-QX411L Screen Replacement: adım 20, 1 resimden 1.
    • Use the small suction cup to lift the screen.
    • Disconnect the wire by pulling it away from the bottom of the screen.
Sonuç
Rebecca Johnson
594 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G3, Hoffman Spring 2017 USF Tampa, Team S19-G3, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,125
