Ana içeriğe geç
Samsung NP-R540-JA09US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP-R540-JA09US RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung NP-R540-JA09US RAM Replacement: adım 2, 1 resimden 1.
    • Pull the two latches outward.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung NP-R540-JA09US RAM Replacement: adım 3, 2 resimden 1. Samsung NP-R540-JA09US RAM Replacement: adım 3, 2 resimden 2.
    • Slide the battery out of the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung NP-R540-JA09US RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Unscrew and remove the two screws from the back panel labeled "Memory" with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung NP-R540-JA09US RAM Replacement: adım 5, 1 resimden 1.
    • Place the flat end of the spudger or your fingers, if possible, between the panel and the laptop. Pry the panel by moving the spudger up and down until the panel can be removed.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung NP-R540-JA09US RAM Replacement: adım 6, 2 resimden 1. Samsung NP-R540-JA09US RAM Replacement: adım 6, 2 resimden 2.
    • Release the two holding pins by pushing them away from each other with your fingers or a spudger.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung NP-R540-JA09US RAM Replacement: adım 7, 1 resimden 1.
    • Pull the RAM out of the laptop with your fingers by gently lifting it up.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 835
