Giriş
Given to us to find out whats happened to the keyboard (Sticky keys), thought it might be helpful to post a guide
  1. Quite a simple stage.  There are a total of 19 screws to be removed from the bottom of the casing. Three for HDD
    • Quite a simple stage. There are a total of 19 screws to be removed from the bottom of the casing.
      • Three for HDD
      • One for Ram/HDD Cover
      • One for ODD
      • one hidden under a rubber foot at the front of the laptop.
      • Three under the Battery
    • Make sure you remove the fake SD Card at the front, because this can stall you.
  2. Once the cover is off, there are three screws holding the main PCB down. Screws for the HDD Battery.  DC 11.1V 57W
    • Once the cover is off, there are three screws holding the main PCB down.
    • Screws for the HDD
    • Battery. DC 11.1V 57W
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. This shows the main PCB USB 3.0 Ports
    • This shows the main PCB
    • USB 3.0 Ports
  5. locations of the main PCB / WIFI card screws. locations of the main PCB / WIFI card screws. locations of the main PCB / WIFI card screws.
    • locations of the main PCB / WIFI card screws.
  6. removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side. removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side. removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side.
    • removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side.
  7. Here's the underside of the main PCB, all cables detached. With the PCB removed this is all you have left.
    • Here's the underside of the main PCB, all cables detached.
    • With the PCB removed this is all you have left.
Sonuç
3 başka kişi bu kılavuzu tamamladı.
Robbie Steele
110 İtibar
1 Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 6
Son 30 Gün: 14
Her zaman: 2,131
