Ana içeriğe geç
Samsung NP270E5E-K03US Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP270E5E-K03US Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Samsung NP270E5E-K03US Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US Hard Drive Replacement: adım 2, 2 resimden 1. Samsung NP270E5E-K03US Hard Drive Replacement: adım 2, 2 resimden 2.
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
  4. Samsung NP270E5E-K03US Hard Drive Replacement: adım 4, 2 resimden 1. Samsung NP270E5E-K03US Hard Drive Replacement: adım 4, 2 resimden 2.
    • Locate the gray hard drive cover, and remove the four corner 3.5mm screws.
  5. Samsung NP270E5E-K03US Hard Drive Replacement: adım 5, 2 resimden 1. Samsung NP270E5E-K03US Hard Drive Replacement: adım 5, 2 resimden 2.
    • Lift the hard drive cover by pulling upwards on the removal handle.
    • You can now remove the hard drive from the laptops housing freeing up space to replace your damaged or broken hard drive with a new hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kyle Golden
353 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G1, Martin Spring 2017 UMass Dartmouth, Team S9-G1, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,751
