Ana içeriğe geç
Samsung NP270E5E-K03US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: adım 1, 2 resimden 1. Samsung NP270E5E-K03US RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: adım 2, 2 resimden 1. Samsung NP270E5E-K03US RAM Replacement: adım 2, 2 resimden 2.
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: adım 4, 3 resimden 1. Samsung NP270E5E-K03US RAM Replacement: adım 4, 3 resimden 2. Samsung NP270E5E-K03US RAM Replacement: adım 4, 3 resimden 3.
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: adım 5, 3 resimden 1. Samsung NP270E5E-K03US RAM Replacement: adım 5, 3 resimden 2. Samsung NP270E5E-K03US RAM Replacement: adım 5, 3 resimden 3.
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: adım 6, 1 resimden 1.
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Golden
353 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G1, Martin Spring 2017 UMass Dartmouth, Team S9-G1, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,136
