Ana içeriğe geç
Samsung NP300E5C Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP300E5C Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Hard Drive Replacement: adım 2, 3 resimden 1. Samsung NP300E5C Hard Drive Replacement: adım 2, 3 resimden 2. Samsung NP300E5C Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Samsung NP300E5C Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Samsung NP300E5C Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Samsung NP300E5C Hard Drive Replacement: adım 4, 3 resimden 1. Samsung NP300E5C Hard Drive Replacement: adım 4, 3 resimden 2. Samsung NP300E5C Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Samsung NP300E5C Hard Drive Replacement: adım 5, 2 resimden 1. Samsung NP300E5C Hard Drive Replacement: adım 5, 2 resimden 2.
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
aliahsan95
937 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S10G13
3 Üyeler
2 Yorum
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - Yanıt
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 49
Her zaman: 12,377
