Ana içeriğe geç
Samsung NP300E5C Optical Drive Replacement
Neye ihtiyacın var
  1. Samsung NP300E5C Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Optical Drive Replacement: adım 2, 3 resimden 1. Samsung NP300E5C Optical Drive Replacement: adım 2, 3 resimden 2. Samsung NP300E5C Optical Drive Replacement: adım 2, 3 resimden 3.
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
  4. Samsung NP300E5C Optical Drive Replacement: adım 4, 2 resimden 1. Samsung NP300E5C Optical Drive Replacement: adım 4, 2 resimden 2.
    • With the 4 mm Phillips #8 screw removed, firmly but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  5. Samsung NP300E5C Optical Drive Replacement: adım 5, 1 resimden 1.
    • Remove the 4 mm Phillips #8 screw to the left of the hard drive using a Phillips #00 screwdriver.
  6. Samsung NP300E5C Optical Drive Replacement: adım 6, 2 resimden 1. Samsung NP300E5C Optical Drive Replacement: adım 6, 2 resimden 2.
    • Using your fingernail or spudger to gently pull your optical drive out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
aliahsan95
937 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S10G13
3 Üyeler
Bir Yorum
Great video, simple steps to follow, very good, thanks.
Chris Hughes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,182
