Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide teaches you how to replace the motherboard in a Samsung NP300E5C laptop.
Neye ihtiyacın var
Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
Firmly, but gently pull the cover towards you.
After moving the cover about 2 centimeters, you can lift and remove it.
Remove the thirteen Philips screws securing the base to the palmrest.
Remove the screw securing the optical drive.
Remove the two small Philips screws securing the base to the palmrest.
Insert a spudger into the separation between the palmrest and the base, in the front of the laptop.
Remove all connectors from the motherboard.
Remove the screws securing the motherboard to the palmrest.
Lift the motherboard out. Remove all components that are connected to the motherboard, such as the wireless card, RAM, CPU, and CPU cooler, to the replacement motherboard. You're done!
3 farklı kişi bu kılavuzu tamamladı.
