Ana içeriğe geç
Samsung NP305E5A-A03US Fan Replacement
Neye ihtiyacın var
  1. Samsung NP305E5A-A03US Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Fan Replacement: adım 2, 1 resimden 1.
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Fan Replacement: adım 3, 2 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 3, 2 resimden 2.
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
  4. Samsung NP305E5A-A03US Fan Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Fan Replacement: adım 5, 1 resimden 1.
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  6. Samsung NP305E5A-A03US Fan Replacement: adım 6, 2 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 6, 2 resimden 2.
    • Pull the panel towards you to remove the panel.
  7. Samsung NP305E5A-A03US Fan Replacement: adım 7, 1 resimden 1.
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Fan Replacement: adım 8, 2 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 8, 2 resimden 2.
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  9. Samsung NP305E5A-A03US Fan Replacement: adım 9, 1 resimden 1.
    • Remove the Hard Drive by lifting it towards you.
  10. Samsung NP305E5A-A03US Fan Replacement, Optical Drive: adım 10, 1 resimden 1.
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  11. Samsung NP305E5A-A03US Fan Replacement: adım 11, 2 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 11, 2 resimden 2.
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  12. Samsung NP305E5A-A03US Fan Replacement: adım 12, 3 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 12, 3 resimden 2. Samsung NP305E5A-A03US Fan Replacement: adım 12, 3 resimden 3.
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  13. Samsung NP305E5A-A03US Fan Replacement: adım 13, 2 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 13, 2 resimden 2.
    • Remove the Optical Drive by sliding it away from the laptop.
  14. Samsung NP305E5A-A03US Fan Replacement, Fan: adım 14, 1 resimden 1.
    • Unscrew the four 8.9mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • The screws will only loosen to the point to where you can remove the vent, so you will not be able to fully remove the screws.
  15. Samsung NP305E5A-A03US Fan Replacement: adım 15, 2 resimden 1. Samsung NP305E5A-A03US Fan Replacement: adım 15, 2 resimden 2.
    • Remove the vent by lifting it away from the laptop.
  16. Samsung NP305E5A-A03US Fan Replacement: adım 16, 1 resimden 1.
    • Pull the cord that connects the Fan to the Motherboard to disconnect it.
  17. Samsung NP305E5A-A03US Fan Replacement: adım 17, 1 resimden 1.
    • Unscrew the two 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  18. Samsung NP305E5A-A03US Fan Replacement: adım 18, 1 resimden 1.
    • Remove the Fan by lifting it towards you.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kris Stobbe
585 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,794
