Ana içeriğe geç
Samsung NP305E5A-A03US Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP305E5A-A03US Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Hard Drive Replacement: adım 2, 1 resimden 1.
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Hard Drive Replacement: adım 3, 2 resimden 1. Samsung NP305E5A-A03US Hard Drive Replacement: adım 3, 2 resimden 2.
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
  4. Samsung NP305E5A-A03US Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Hard Drive Replacement: adım 5, 1 resimden 1.
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  6. Samsung NP305E5A-A03US Hard Drive Replacement: adım 6, 2 resimden 1. Samsung NP305E5A-A03US Hard Drive Replacement: adım 6, 2 resimden 2.
    • Pull the panel towards you to remove the panel.
  7. Samsung NP305E5A-A03US Hard Drive Replacement: adım 7, 1 resimden 1.
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Hard Drive Replacement: adım 8, 2 resimden 1. Samsung NP305E5A-A03US Hard Drive Replacement: adım 8, 2 resimden 2.
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  9. Samsung NP305E5A-A03US Hard Drive Replacement: adım 9, 1 resimden 1.
    • Remove the Hard Drive by lifting it towards you.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Oyinda Olatundee
125 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G7
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Necesito un hard drive model: NO305E5A-A05US
Secundino Herrera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 1,832
