Ana içeriğe geç
Samsung NP305E5A-A03US Optical Drive Replacement
Neye ihtiyacın var
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: adım 2, 1 resimden 1.
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: adım 3, 2 resimden 1. Samsung NP305E5A-A03US Optical Drive Replacement: adım 3, 2 resimden 2.
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: adım 4, 1 resimden 1.
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: adım 5, 2 resimden 1. Samsung NP305E5A-A03US Optical Drive Replacement: adım 5, 2 resimden 2.
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: adım 6, 1 resimden 1.
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: adım 7, 1 resimden 1.
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: adım 8, 2 resimden 1. Samsung NP305E5A-A03US Optical Drive Replacement: adım 8, 2 resimden 2.
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: adım 9, 3 resimden 1. Samsung NP305E5A-A03US Optical Drive Replacement: adım 9, 3 resimden 2. Samsung NP305E5A-A03US Optical Drive Replacement: adım 9, 3 resimden 3.
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: adım 10, 2 resimden 1. Samsung NP305E5A-A03US Optical Drive Replacement: adım 10, 2 resimden 2.
    • Remove the Optical Drive by sliding it away from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kris Stobbe
585 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 335
