Giriş
This guide will help you replace your malfunctioning optical drive. You may want to use this guide if your CD/DVD drive is unresponsive.
Neye ihtiyacın var
Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
Bir başkası bu kılavuzu tamamladı.
