Ana içeriğe geç
Samsung NP305E5A-A03US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US RAM Replacement: adım 2, 1 resimden 1.
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US RAM Replacement: adım 3, 2 resimden 1. Samsung NP305E5A-A03US RAM Replacement: adım 3, 2 resimden 2.
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US RAM Replacement: adım 4, 1 resimden 1.
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US RAM Replacement: adım 5, 2 resimden 1. Samsung NP305E5A-A03US RAM Replacement: adım 5, 2 resimden 2.
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US RAM Replacement: adım 6, 1 resimden 1.
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US RAM Replacement, RAM: adım 7, 1 resimden 1.
    • Place your thumbs on the metal tabs.
    • Push outwards on the metal tabs to release the RAM.
  8. Samsung NP305E5A-A03US RAM Replacement: adım 8, 2 resimden 1. Samsung NP305E5A-A03US RAM Replacement: adım 8, 2 resimden 2.
    • Pull out the RAM towards you to remove it from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Julia Dotter
224 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 436
