Ana içeriğe geç
Samsung NP350E5C-A02US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP350E5C-A02US RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US RAM Replacement: adım 2, 1 resimden 1.
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US RAM Replacement: adım 3, 1 resimden 1.
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US RAM Replacement, Hard drive and memory stick cover: adım 4, 1 resimden 1.
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US RAM Replacement: adım 5, 1 resimden 1.
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US RAM Replacement: adım 6, 1 resimden 1.
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US RAM Replacement, RAM: adım 7, 1 resimden 1.
    • Gently push the lock springs outwards and the RAM stick will rise when it's free.
  8. Samsung NP350E5C-A02US RAM Replacement: adım 8, 1 resimden 1.
    • Then, gently pull the RAM stick towards the front of the laptop.
  9. Samsung NP350E5C-A02US RAM Replacement: adım 9, 1 resimden 1.
    • Repeat the last two steps for the second RAM stick if needed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 278
