Ana içeriğe geç
Samsung NP350E5C-A02US Wifi card Replacement
Neye ihtiyacın var
  1. Samsung NP350E5C-A02US Wifi card Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Wifi card Replacement: adım 2, 1 resimden 1.
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Wifi card Replacement: adım 3, 1 resimden 1.
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Wifi card Replacement, Wifi card: adım 4, 1 resimden 1.
    • Look for the compartment with the Wifi symbol on it.
  5. Samsung NP350E5C-A02US Wifi card Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
  6. Samsung NP350E5C-A02US Wifi card Replacement: adım 6, 1 resimden 1.
    • Gently pry up cover using a plastic spudger or opening tool.
  7. Samsung NP350E5C-A02US Wifi card Replacement: adım 7, 1 resimden 1.
    • Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
  8. Samsung NP350E5C-A02US Wifi card Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
  9. Samsung NP350E5C-A02US Wifi card Replacement: adım 9, 1 resimden 1.
    • Gently pull out the Wifi card.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 280
