Ana içeriğe geç
Samsung NP350V5C-T02US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP350V5C-T02US RAM Replacement, ODD/HDD/Memory Cover: adım 1, 1 resimden 1.
    • Flip the laptop over so that the bottom is facing toward you.
  2. Samsung NP350V5C-T02US RAM Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
  3. Samsung NP350V5C-T02US RAM Replacement: adım 3, 1 resimden 1.
    • Using your hand slide the ODD/HDD/Memory panel off in a downward motion.
  4. Samsung NP350V5C-T02US RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Locate the RAM in the lower right hand corner.
  5. Samsung NP350V5C-T02US RAM Replacement: adım 5, 1 resimden 1.
    • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
    • Since there are two RAMs, remove the other one by using the same method.
  6. Samsung NP350V5C-T02US RAM Replacement: adım 6, 1 resimden 1.
    • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
Sonuç
Bir Yorum
Hello,
Thank you for all of the guides. I was curious if you know what the maximum amount of RAM that this laptop can be upgraded to?
On the Samsung site, it says the max is 8 GB, however the Intel site says 32 GB is the max for the processor.
Could the difference be the motherboard?
Thanks!
Will
Will Terfansky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 980
