Ana içeriğe geç
Samsung NP350V5C-T02US Wifi card Replacement
Neye ihtiyacın var
  1. Samsung NP350V5C-T02US Wifi card Replacement, Wifi card: adım 1, 1 resimden 1.
    • Flip over the laptop so you are facing the backside.
  2. Samsung NP350V5C-T02US Wifi card Replacement: adım 2, 3 resimden 1. Samsung NP350V5C-T02US Wifi card Replacement: adım 2, 3 resimden 2. Samsung NP350V5C-T02US Wifi card Replacement: adım 2, 3 resimden 3.
    • Look for the compartment with the Wifi symbol on it.
    • Using the Phillips #1 screwdriver remove the M2.5X5 screw, located beside the Wifi Symbol.
    • Using the plastic spudger, carefully pry the Wifi panel off.
  3. Samsung NP350V5C-T02US Wifi card Replacement: adım 3, 2 resimden 1. Samsung NP350V5C-T02US Wifi card Replacement: adım 3, 2 resimden 2.
    • Gently remove the two wires attached to the the Wifi card by using the plastic spudger to pry from underneath the attachment points.
    • Using the #2 Phillips screwdriver, remove the M2.5X3 mm screw holding in the Wifi card
  4. Samsung NP350V5C-T02US Wifi card Replacement: adım 4, 2 resimden 1. Samsung NP350V5C-T02US Wifi card Replacement: adım 4, 2 resimden 2.
    • Using you hand, gently pull out the Wifi card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Syed Asad
240 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,000
