Ana içeriğe geç
Samsung NP36535C-S05US CD Drive Replacement
Neye ihtiyacın var
  1. Samsung NP36535C-S05US CD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US CD Drive Replacement: adım 2, 1 resimden 1.
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US CD Drive Replacement: adım 3, 2 resimden 1. Samsung NP36535C-S05US CD Drive Replacement: adım 3, 2 resimden 2.
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US CD Drive Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 1. Samsung NP36535C-S05US CD Drive Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 2. Samsung NP36535C-S05US CD Drive Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 3.
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
  5. Samsung NP36535C-S05US CD Drive Replacement, CD Drive: adım 5, 2 resimden 1. Samsung NP36535C-S05US CD Drive Replacement, CD Drive: adım 5, 2 resimden 2.
    • Locate the screw on the right side of the SDD port.
    • Remove the 2.25 mm screw located on the right side of the SDD port with the Philips #0 screwdriver.
  6. Samsung NP36535C-S05US CD Drive Replacement: adım 6, 3 resimden 1. Samsung NP36535C-S05US CD Drive Replacement: adım 6, 3 resimden 2. Samsung NP36535C-S05US CD Drive Replacement: adım 6, 3 resimden 3.
    • Locate the CD drive and slide the drive out of the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Hie guys my laptop is not displaying
please help what should i do
semzeajunior - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 326
