Ana içeriğe geç
Samsung NP36535C-S05US Key Replacement
Neye ihtiyacın var
  1. Samsung NP36535C-S05US Key Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US Key Replacement: adım 2, 1 resimden 1.
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US Key Replacement: adım 3, 2 resimden 1. Samsung NP36535C-S05US Key Replacement: adım 3, 2 resimden 2.
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US Key Replacement, Key: adım 4, 3 resimden 1. Samsung NP36535C-S05US Key Replacement, Key: adım 4, 3 resimden 2. Samsung NP36535C-S05US Key Replacement, Key: adım 4, 3 resimden 3.
    • There is an outer and inner piece of the retainer. The outer retainer has two (2) grooves for the inner retainer's posts to sit in.
    • Place the inner retainer piece into the outer retainer piece by inserting the posts into the grooves on the outer retainer piece.
  5. Samsung NP36535C-S05US Key Replacement: adım 5, 3 resimden 1. Samsung NP36535C-S05US Key Replacement: adım 5, 3 resimden 2. Samsung NP36535C-S05US Key Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    $3.99
    • There are two (2) grooves on the outer retainer that fit onto two (2) metal brackets on the key's designated space.
    • Use angled tweezers to place the assembled retainer onto the two (2) metal brackets on the keyboard.
  6. Samsung NP36535C-S05US Key Replacement: adım 6, 3 resimden 1. Samsung NP36535C-S05US Key Replacement: adım 6, 3 resimden 2. Samsung NP36535C-S05US Key Replacement: adım 6, 3 resimden 3.
    • Once the retainer is attached, press the key onto the retainer, it will make a snapping sound when in place.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 355
