Ana içeriğe geç
Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement
Neye ihtiyacın var
  1. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: adım 2, 1 resimden 1.
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: adım 3, 2 resimden 1. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: adım 3, 2 resimden 2.
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 1. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 2. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 3.
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 1,372
