Ana içeriğe geç
Samsung NP36535C-S05US RAM Replacement
Neye ihtiyacın var
  1. Samsung NP36535C-S05US RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US RAM Replacement: adım 2, 1 resimden 1.
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US RAM Replacement: adım 3, 2 resimden 1. Samsung NP36535C-S05US RAM Replacement: adım 3, 2 resimden 2.
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US RAM Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 1. Samsung NP36535C-S05US RAM Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 2. Samsung NP36535C-S05US RAM Replacement, ODD/HDD/Memory panel: adım 4, 3 resimden 3.
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
  5. Samsung NP36535C-S05US RAM Replacement, RAM: adım 5, 2 resimden 1. Samsung NP36535C-S05US RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Locate the two (2) RAM chips in the upper left corner.
  6. Samsung NP36535C-S05US RAM Replacement: adım 6, 3 resimden 1. Samsung NP36535C-S05US RAM Replacement: adım 6, 3 resimden 2. Samsung NP36535C-S05US RAM Replacement: adım 6, 3 resimden 3.
    • Locate the two (2) metal brackets holding the RAM chip in place.
    • Carefully push the brackets outwards away from the RAM chip, causing it to pop out of the brackets.
    • Remove the first RAM chip by pulling it up and out of its plug.
  7. Samsung NP36535C-S05US RAM Replacement: adım 7, 3 resimden 1. Samsung NP36535C-S05US RAM Replacement: adım 7, 3 resimden 2. Samsung NP36535C-S05US RAM Replacement: adım 7, 3 resimden 3.
    • Locate the second set of metal brackets holding the remaining RAM chip.
    • Remove the second RAM chip by pulling it up and out of its plug.
  8. Samsung NP36535C-S05US RAM Replacement: adım 8, 1 resimden 1.
    • You have successfully removed the RAM chips.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 292
