Ana içeriğe geç
Samsung NP510R5E-A01UB Speaker Replacement
Neye ihtiyacın var
  1. Samsung NP510R5E-A01UB Speaker Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Speaker Replacement: adım 2, 1 resimden 1.
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Speaker Replacement: adım 3, 2 resimden 1. Samsung NP510R5E-A01UB Speaker Replacement: adım 3, 2 resimden 2.
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: adım 4, 3 resimden 1. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: adım 4, 3 resimden 2. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Speaker Replacement: adım 5, 2 resimden 1. Samsung NP510R5E-A01UB Speaker Replacement: adım 5, 2 resimden 2.
    • Untangle the wires attached to the exterior of the right speaker.
    • Lift the tape up holding the wires down to fully release the wires.
  6. Samsung NP510R5E-A01UB Speaker Replacement: adım 6, 1 resimden 1.
    • Unscrew the 3.4mm long screw holding the right speaker in place.
  7. Samsung NP510R5E-A01UB Speaker Replacement: adım 7, 1 resimden 1.
    • Pull up on the wires circled to disconnect the right speaker.
  8. Samsung NP510R5E-A01UB Speaker Replacement: adım 8, 1 resimden 1.
    • Using the plastic opening tool, pry up the right speaker and take it out.
  9. Samsung NP510R5E-A01UB Speaker Replacement: adım 9, 1 resimden 1.
    • Unscrew the 3.4mm long screw holding the left speaker in place.
  10. Samsung NP510R5E-A01UB Speaker Replacement: adım 10, 1 resimden 1.
    • Pull up on the wires to disconnect the left speaker.
  11. Samsung NP510R5E-A01UB Speaker Replacement: adım 11, 1 resimden 1.
    • Using the plastic opening tool, pry up the left speaker and take it out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian Briggs
529 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G5, Eyestone Spring 2018 USF Tampa, Team S6-G5, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S6G5
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 256
