Giriş
In this guide you will be learning how to remove the battery from your Samsung NP5230U4BL laptop. This will enable you to replace a damaged damaged or outdated battery to potentially improve battery life. Before attempting to remove the battery, be sure to ground yourself with an anti-static wrist strap and have a Philips #00 Screwdriver, as well as a Nylon pry tool on standby. Also carefully follow the given instructions including the cautionary warnings.
Neye ihtiyacın var
Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
On each side of the portion that is jutting out, there is one, silver 1.5 mm screw. Using the Phillips #00 screwdriver, remove these two screws.
4 farklı kişi bu kılavuzu tamamladı.
