Ana içeriğe geç
Samsung NP540U3C-A02UB Battery Replacement
Neye ihtiyacın var
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: adım 2, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 2, 2 resimden 2.
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: adım 3, 3 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 3, 3 resimden 2. Samsung NP540U3C-A02UB Battery Replacement: adım 3, 3 resimden 3.
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: adım 4, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 4, 2 resimden 2.
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: adım 5, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: adım 6, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 6, 2 resimden 2.
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: adım 7, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement, Battery: adım 7, 2 resimden 2.
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: adım 8, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 8, 2 resimden 2.
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: adım 9, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 9, 2 resimden 2.
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: adım 10, 1 resimden 1.
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: adım 11, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 11, 2 resimden 2.
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: adım 12, 3 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 12, 3 resimden 2. Samsung NP540U3C-A02UB Battery Replacement: adım 12, 3 resimden 3.
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: adım 13, 2 resimden 1. Samsung NP540U3C-A02UB Battery Replacement: adım 13, 2 resimden 2.
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: adım 14, 1 resimden 1.
    • Remove the battery from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alejandro
253 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SCG1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 937
