Ana içeriğe geç
Samsung NP540U3C-A02UB Fan Replacement
Neye ihtiyacın var
  1. Samsung NP540U3C-A02UB Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect from the charging cable before beginning disassembly.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Fan Replacement: adım 2, 2 resimden 1. Samsung NP540U3C-A02UB Fan Replacement: adım 2, 2 resimden 2.
    • Remove the 1x 4mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Fan Replacement: adım 3, 3 resimden 1. Samsung NP540U3C-A02UB Fan Replacement: adım 3, 3 resimden 2. Samsung NP540U3C-A02UB Fan Replacement: adım 3, 3 resimden 3.
    • Gently release the three clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Fan Replacement: adım 4, 1 resimden 1.
    • Peel the yellow tape up so it no longer blocks the fan's wires and screw.
  5. Samsung NP540U3C-A02UB Fan Replacement: adım 5, 1 resimden 1.
    • Remove the two 2.4mm Phillips #00 screws attaching the fan to the case.
    • Remove the two 6mm Phillips #00 screws attaching the fan to the case.
  6. Samsung NP540U3C-A02UB Fan Replacement: adım 6, 2 resimden 1. Samsung NP540U3C-A02UB Fan Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, gently disconnect the fan from the motherboard by unplugging the wire.
  7. Samsung NP540U3C-A02UB Fan Replacement: adım 7, 1 resimden 1.
    • Remove the fan from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Colby Bolger
277 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SCG1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 470
