Ana içeriğe geç
Samsung NP540U3C-A02UB Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung NP540U3C-A02UB Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 2, 2 resimden 1. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 3, 3 resimden 1. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 3, 3 resimden 2. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 3, 3 resimden 3.
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 4, 2 resimden 1. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 5, 2 resimden 1. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 6, 2 resimden 1. Samsung NP540U3C-A02UB Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the hard drive from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Bourgeois
269 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SCG1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 613
