Ana içeriğe geç
Samsung NP700Z5AH Battery Replacement
Neye ihtiyacın var
  1. Samsung NP700Z5AH Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Battery Replacement: adım 2, 3 resimden 1. Samsung NP700Z5AH Battery Replacement: adım 2, 3 resimden 2. Samsung NP700Z5AH Battery Replacement: adım 2, 3 resimden 3.
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Battery Replacement: adım 3, 2 resimden 1. Samsung NP700Z5AH Battery Replacement: adım 3, 2 resimden 2.
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Battery Replacement: adım 4, 2 resimden 1. Samsung NP700Z5AH Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Battery Replacement: adım 5, 1 resimden 1.
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Battery Replacement: adım 6, 2 resimden 1. Samsung NP700Z5AH Battery Replacement: adım 6, 2 resimden 2.
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
ifixit@distinctlydifferent.co.uk
Jacqueline - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 19
Her zaman: 1,157
