Ana içeriğe geç
Samsung NP700Z5AH Display Replacement
Neye ihtiyacın var
  1. Samsung NP700Z5AH Display Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung NP700Z5AH Display Replacement: adım 2, 3 resimden 1. Samsung NP700Z5AH Display Replacement: adım 2, 3 resimden 2. Samsung NP700Z5AH Display Replacement: adım 2, 3 resimden 3.
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung NP700Z5AH Display Replacement: adım 3, 2 resimden 1. Samsung NP700Z5AH Display Replacement: adım 3, 2 resimden 2.
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
    FixBot'a Sor
    Yorum Ekle
  4. Samsung NP700Z5AH Display Replacement: adım 4, 2 resimden 1. Samsung NP700Z5AH Display Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung NP700Z5AH Display Replacement: adım 5, 1 resimden 1.
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung NP700Z5AH Display Replacement: adım 6, 2 resimden 1. Samsung NP700Z5AH Display Replacement: adım 6, 2 resimden 2.
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung NP700Z5AH Display Replacement, Display: adım 7, 2 resimden 1. Samsung NP700Z5AH Display Replacement, Display: adım 7, 2 resimden 2.
    • Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
    • After they are disconnected, un-thread the coaxial connectors from around the fan.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors "snap" into their sockets much like the metal snaps on a jacket.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung NP700Z5AH Display Replacement: adım 8, 3 resimden 1. Samsung NP700Z5AH Display Replacement: adım 8, 3 resimden 2. Samsung NP700Z5AH Display Replacement: adım 8, 3 resimden 3.
    • Using the Phillips#00, remove the single 3.5mm screw from the wireless card.
    • Grasp the edges of the wireless card with your fingers and pull straight backwards to remove it.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung NP700Z5AH Display Replacement: adım 9, 2 resimden 1. Samsung NP700Z5AH Display Replacement: adım 9, 2 resimden 2.
    • Using the Phillips#00, remove the six 4.5mm screws from the corner brackets holding the display to the inner case.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung NP700Z5AH Display Replacement: adım 10, 3 resimden 1. Samsung NP700Z5AH Display Replacement: adım 10, 3 resimden 2. Samsung NP700Z5AH Display Replacement: adım 10, 3 resimden 3.
    • Using your fingers, grasp the edges of the inner case then lift and pull away to separate it from the display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 1,270
