Giriş
Use this guide if your computer is overheating, or if you are hearing a sound originating from the fan.
Neye ihtiyacın var
First turn the computer over so you are looking at the back panel.
Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
Bir başkası bu kılavuzu tamamladı.
