Ana içeriğe geç
Samsung NP900X4B Fan Replacement
Neye ihtiyacın var
  1. Samsung NP900X4B Fan Replacement, Back Panel: adım 1, 2 resimden 1. Samsung NP900X4B Fan Replacement, Back Panel: adım 1, 2 resimden 2.
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: adım 2, 1 resimden 1.
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: adım 3, 2 resimden 1. Samsung NP900X4B Fan Replacement: adım 3, 2 resimden 2.
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: adım 4, 2 resimden 1. Samsung NP900X4B Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: adım 5, 1 resimden 1.
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: adım 6, 2 resimden 1. Samsung NP900X4B Fan Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: adım 7, 1 resimden 1.
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian Miller
333 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S4G6
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 180
